주요 콘텐츠로 건너뛰기
Toshiba Satellite M55-S135 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite M55-S135 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Use the Phillips 00 screwdriver to remove the 3.62mm screw.
  2. Toshiba Satellite M55-S135 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the plastic cover from the laptop.
  3. Toshiba Satellite M55-S135 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pull the black plastic tab horizontally away from the hard drive to disconnect and remove the hard drive from the laptop.
  4. Toshiba Satellite M55-S135 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use the Phillips 00 screwdriver to remove the four 6.50mm screws on the sides of hard drive.
  5. Toshiba Satellite M55-S135 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite M55-S135 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Use the Phillips 00 screwdriver to remove the other four 6.50mm screws on hard drive.
    • Remove the washer strips (the metal strips that the screws held down) from the hard drive.
  6. Toshiba Satellite M55-S135 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Pull the black tab away from the hard drive to separate the hard drive and the casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matthew Trinh
회원 가입일: 01/31/13
63 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 회원
CPSU-MANESS-W13S7G11
4 회원들
안내서 5개 작성하였습니다
댓글 2개
I have a regular SATA 2.5 hard drive and it won't fit my M55-S1001. Is there something else I need??
Matthew Halbert - 답글
According to http://www.rakuten.com/prod/120gb-hard-d..., your hard drive is the right size. If it doesn't fit, check to see if the pins connect correctly and if your laptop accepts a SATA drive and not a PATA drive; this image can help http://www.laptopking.com/sata_identify.....
Next, check if you're inserting it correctly. I haven't experienced replacing the hard drive with the M55-S1001, but I assume it's the same method as the M55-S135 (though it could be different).
I'm unsure if there's anything else you would need besides the correct type of screwdriver to unlock the casing but I doubt it.
Matthew Trinh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 3,935
