주요 콘텐츠로 건너뛰기
Toshiba Satellite M55-S135 Keyboard Replacement
필요한 것
  1. Toshiba Satellite M55-S135 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Toshiba Satellite M55-S135 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite M55-S135 Keyboard Replacement: 2 단계, 이미지 2/2
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. Toshiba Satellite M55-S135 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite M55-S135 Keyboard Replacement: 3 단계, 이미지 2/2
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  4. Toshiba Satellite M55-S135 Keyboard Replacement: 4 단계, 이미지 1/1
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  5. Toshiba Satellite M55-S135 Keyboard Replacement: 5 단계, 이미지 1/1
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
결론
klismann Evora
회원 가입일: 03/12/14
109 평판
안내서 1개 작성함
UMass Dartmouth, Team 5-7, Cichon Spring 2014 UMass Dartmouth, Team 5-7, Cichon Spring 2014 회원
UMASSD-CICHON-S14S5G7
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 694
