주요 콘텐츠로 건너뛰기
Toshiba Satellite M55-S135 RAM Replacement
필요한 것
  1. Toshiba Satellite M55-S135 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 RAM Replacement: 2 단계, 이미지 1/1
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite M55-S135 RAM Replacement: 3 단계, 이미지 2/2
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
결론
Matthew Trinh
회원 가입일: 01/31/13
63 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 회원
CPSU-MANESS-W13S7G11
4 회원들
안내서 5개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,318
