주요 콘텐츠로 건너뛰기
Toshiba Satellite M55-S135 Screen Replacement
필요한 것
  1. Toshiba Satellite M55-S135 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
    • Slide the unlock switch in the top left-hand corner to the left/unlock position.
  2. Toshiba Satellite M55-S135 Screen Replacement: 2 단계, 이미지 1/1
    • Hold the switch in upper right-hand corner to the right.
    • With the switch held open, pull the battery straight away from the laptop.
  3. Toshiba Satellite M55-S135 Screen Replacement, Screen: 3 단계, 이미지 1/2 Toshiba Satellite M55-S135 Screen Replacement, Screen: 3 단계, 이미지 2/2
    • Use the plastic opening tool to remove the four small rubber pop-out squares from the corners of your screen.
    • The laptop displayed in the picture does not have these plastic squares.
  4. Toshiba Satellite M55-S135 Screen Replacement: 4 단계, 이미지 1/2 Toshiba Satellite M55-S135 Screen Replacement: 4 단계, 이미지 2/2
    • Use the Phillips 00 screwdriver to unscrew the four 6.72mm screws from the corners of the screen.
    • The screws will be located underneath the previously removed black squares.
  5. Toshiba Satellite M55-S135 Screen Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to pop off the black plastic casing that surrounds the screen.
  6. Toshiba Satellite M55-S135 Screen Replacement: 6 단계, 이미지 1/2 Toshiba Satellite M55-S135 Screen Replacement: 6 단계, 이미지 2/2
    • Use the Phillips 00 screwdriver to remove the two 6.72mm screws at the bottom left and right of the screen.
  7. Toshiba Satellite M55-S135 Screen Replacement: 7 단계, 이미지 1/2 Toshiba Satellite M55-S135 Screen Replacement: 7 단계, 이미지 2/2
    • Turn the laptop 90 degrees clockwise.
    • Use the Phillips 00 screwdriver to remove the six 3.78mm screws from both sides of the screen.
    • Hold on to the screen while removing the screws.
  8. Toshiba Satellite M55-S135 Screen Replacement: 8 단계, 이미지 1/1
    • Fold the screen down so that the back of the screen is visible.
    • Remove the yellow wiring connected to the top of the back of the screen by pulling it out and then up.
  9. Toshiba Satellite M55-S135 Screen Replacement: 9 단계, 이미지 1/1
    • Use the Phillips 00 screwdriver to remove the 5.54mm screw connecting the green panel to the laptop frame.
  10. Toshiba Satellite M55-S135 Screen Replacement: 10 단계, 이미지 1/1
    • Pull out the green panel and disconnect the black cable from the belly of the green panel.
    • The screen should be fully disconnected from laptop at this point.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Trinh
회원 가입일: 01/31/13
63 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 회원
CPSU-MANESS-W13S7G11
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,097
