주요 콘텐츠로 건너뛰기
Toshiba Satellite P105-S6147 Cooling Fan Replacement
필요한 것
  1. Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Begin by placing the laptop face down on a flat surface.
    • The battery is located in the bottom left hand corner of the device.
    • Slide the lock switch on the battery to the unlocked position.
    • Slide the release lever on the battery towards the lock switch. The battery should now rotate out of its dock in the laptop.
  2. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 2 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 2 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the casing located next to the battery.
    • Using a #0 Phillips screwdriver, remove the two 4 mm screws.
    • Use the precision tweezers to disconnect the white and black wire from the device.
    • Remove the thin black wire from the device.
  3. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Open the remaining casings using a #0 Phillips screwdriver.
    • Remove all visible screws on the bottom of the laptop to complete this step.
  4. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 4 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 4 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Hold the back cover slightly open.
    • Use the precision tweezers to disconnect the two ribbon cables at the bottom of the laptop.
    • Open the small black clips to free the ribbon cables.
    • Remove the back cover.
  5. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the white plug in the upper right hand corner of the laptop.
    • Use the iFixit opening tools to apply even, backwards pressure to each side of the plug until the plug is free from the motherboard.
  6. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the ribbon cable on the bottom of the laptop.
    • Open the small black clip that is holding the ribbon cable.
    • Gently remove the ribbon cable with the precision tweezers.
  7. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the white plug next to the ribbon cable that was removed in the previous step.
    • Gently unplug the plug with your hand or the blue iFixit opening tools.
  8. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the motherboard from the laptop casing.
  9. Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: 9 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: 9 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the precision tweezers to remove the metal cover off the top of the cooling fan. It should "pop" off with little effort.
    • Flip over the motherboard.
    • The cooling fan is now located in the upper left-hand corner of the motherboard.
  10. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 10 단계, 이미지 2개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the two 5 mm screws located at the bottom right of the cooling fan.
    • The cooling fan housing is now free from the motherboard.
  11. Toshiba Satellite P105-S6147 Cooling Fan Replacement: 11 단계, 이미지 2개 중 1개 Toshiba Satellite P105-S6147 Cooling Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Locate the white plug connecting the cooling fan to the motherboard.
    • Gently pull on the plug to disconnect the cooling fan from the motherboard.
    • Remove the cooling fan from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Benjamin Wilkinson
회원 가입일: 09/21/18
905 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 277
