주요 콘텐츠로 건너뛰기
Toshiba Satellite P105-S6147 Keyboard Replacement
필요한 것
  1. Toshiba Satellite P105-S6147 Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite P105-S6147 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite P105-S6147 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Benjamin Wilkinson
회원 가입일: 09/21/18
905 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 22
전체 시간: 284
