주요 콘텐츠로 건너뛰기
Toshiba Satellite P105-S6147 Keyboard Replacement
필요한 것
  1. Toshiba Satellite P105-S6147 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Keyboard Replacement: 2 단계, 이미지 1/1
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite P105-S6147 Keyboard Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Keyboard Replacement: 4 단계, 이미지 1/3 Toshiba Satellite P105-S6147 Keyboard Replacement: 4 단계, 이미지 2/3 Toshiba Satellite P105-S6147 Keyboard Replacement: 4 단계, 이미지 3/3
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite P105-S6147 Keyboard Replacement: 5 단계, 이미지 2/2
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Benjamin Wilkinson
회원 가입일: 09/21/18
905 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 225
