주요 콘텐츠로 건너뛰기
Toshiba Satellite P105-S6147 RAM Replacement
  1. Toshiba Satellite P105-S6147 RAM Replacement, RAM: 1 단계, 이미지 1개 중 1개
    • Begin with the laptop laying down on a flat surface, with the bottom facing up.
  2. Toshiba Satellite P105-S6147 RAM Replacement: 2 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 RAM Replacement: 2 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 RAM Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the battery from the device.
    • The battery is located in the bottom, left hand corner of the device.
    • Slide the lock switch to the unlocked position.
    • Slide the release lever towards the unlock switch. The battery should now rotate out of its dock in the laptop.
  3. Toshiba Satellite P105-S6147 RAM Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite P105-S6147 RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Open the casing directly above the battery.
    • Use a Phillips #0 screwdriver to remove two 4 mm screws located at the top of the casing.
    • Once the cover is removed the RAM sticks will be visible.
  4. Toshiba Satellite P105-S6147 RAM Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite P105-S6147 RAM Replacement: 4 단계, 이미지 2개 중 2개
    • Use a nylon spudger to disconnect the tabs from the RAM. The tabs are located on either side of the RAM.
    • Apply light, outward force to the tabs.
  5. Toshiba Satellite P105-S6147 RAM Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Satellite P105-S6147 RAM Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Satellite P105-S6147 RAM Replacement: 5 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to apply light pressure to the bottom of the upper RAM stick.
    • The RAM stick should come loose and be removable by hand.
    • Repeat the previous steps to remove the lower RAM stick.
결론
작성자
6다른 기여자 명과 함께
Benjamin Wilkinson
회원 가입일: 09/21/18
905 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 227
