주요 콘텐츠로 건너뛰기
Toshiba Satellite P205-S8811 Disk Drive Replacement
필요한 것
  1. Toshiba Satellite P205-S8811 Disk Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Disk Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Disk Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Disk Drive Replacement: 2 단계, 이미지 2/2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Disk Drive Replacement, Disk Drive: 3 단계, 이미지 1/1
    • Remove the 8mm Phillips #1 screw that holds the disk drive in place.
  4. Toshiba Satellite P205-S8811 Disk Drive Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry out the disk drive.
  5. Toshiba Satellite P205-S8811 Disk Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Disk Drive Replacement: 5 단계, 이미지 2/2
    • Once the disk drive becomes loose, slowly slide it out and set it aside.
결론
Bradley Johnson
회원 가입일: 02/02/14
214 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G8
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 405
