주요 콘텐츠로 건너뛰기
Toshiba Satellite P205-S8811 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Use a #1 Phillips screwdriver to take out the 8mm Phillips #1 screw holding the hard drive panel on.
  4. Toshiba Satellite P205-S8811 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Place one finger under the tab of the hard drive panel and lift up with medium force.
  5. Toshiba Satellite P205-S8811 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Hold the black tab attached to the hard drive and pull with medium force to the side that the tab is on. This will pull the hard drive out of it's socket.
  6. Toshiba Satellite P205-S8811 Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Use a #1 Phillips screwdriver to unscrew the four 4mm Phillips #1 screws (2 on each side) holding the brackets to the hard drive.
    • With the screws undone, the brackets should come right off. Next, pull on the black tab again to pull the cover off of the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Meyer
회원 가입일: 02/03/14
245 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G8
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
There is a missing step between 4 and 5.
- Remove the screw(s) that hold the HDD assembly in its compartment.
...only then can you move on to step 5.
Robert Cartier - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,047
