이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If your hard drive is malfunctioning or if you want to replace it, this guide will show you how to take it out.
필요한 것
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Use a #1 Phillips screwdriver to take out the 8mm Phillips #1 screw holding the hard drive panel on.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
There is a missing step between 4 and 5.
- Remove the screw(s) that hold the HDD assembly in its compartment.
...only then can you move on to step 5.
