주요 콘텐츠로 건너뛰기
Toshiba Satellite P205-S8811 Keyboard Replacement
필요한 것
  1. Toshiba Satellite P205-S8811 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Place the head of a plastic opening tool underneath the plastic strip lining the top of the keyboard, right above the "PGUP" button.
    • Next, pull the strip up using a plastic opening tool with a light force, until it pops off.
  4. Toshiba Satellite P205-S8811 Keyboard Replacement: 4 단계, 이미지 1/1
    • Lightly lift from the side that was popped up earlier in order to pop the rest of the strip off of the laptop.
  5. Toshiba Satellite P205-S8811 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite P205-S8811 Keyboard Replacement: 5 단계, 이미지 2/2
    • Use a #1 Phillips screwdriver to take out the four 4mm Phillips #1 screws that were underneath the plastic strip.
  6. Toshiba Satellite P205-S8811 Keyboard Replacement: 6 단계, 이미지 1/3 Toshiba Satellite P205-S8811 Keyboard Replacement: 6 단계, 이미지 2/3 Toshiba Satellite P205-S8811 Keyboard Replacement: 6 단계, 이미지 3/3
    • Be careful to not lift up on the keyboard too quickly or harshly; there is a ribbon cable connecting the keyboard and the base which may be breakable.
    • Lightly lift up on the keyboard from one of its top corners and pull it towards the screen so you can safely remove the ribbon cable.
    • At the base of the ribbon cable, there is a tiny tab that runs across the width of the connector. Flip it up. You can now pull the ribbon cable free with no resistance towards the monitor.
    • With the cable unplugged, the keyboard can be lifted away from the laptop.
결론
Andrew Meyer
회원 가입일: 02/03/14
245 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G8
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 777
