주요 콘텐츠로 건너뛰기
Toshiba Satellite P205D-S8804 Battery Replacement
  1. Toshiba Satellite P205D-S8804 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down on a flat surface with the screen closed.
  2. Toshiba Satellite P205D-S8804 Battery Replacement: 2 단계, 이미지 1/1
    • Slide the battery lock (marked with a 1), located at the top of the battery compartment, to the right.
  3. Toshiba Satellite P205D-S8804 Battery Replacement: 3 단계, 이미지 1/1
    • Slide the far left latch (marked with a 2) to the left and hold while lifting the battery upward.
  4. Toshiba Satellite P205D-S8804 Battery Replacement: 4 단계, 이미지 1/1
    • Lift the battery to completely remove it from the laptop.
결론
Tommy Wiffler
회원 가입일: 01/31/17
1 평판
안내서 1개 작성함
Baylor, Team 3-2, Whitney Spring 2017 Baylor, Team 3-2, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 130
