주요 콘텐츠로 건너뛰기
Toshiba Satellite P205D-S8804 CD Drive Replacement
필요한 것
  1. Toshiba Satellite P205D-S8804 CD Drive Replacement, Keyboard: 1 단계, 이미지 1/1
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 CD Drive Replacement: 2 단계, 이미지 1/1
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 CD Drive Replacement: 3 단계, 이미지 1/1
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 CD Drive Replacement: 4 단계, 이미지 1/1
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 CD Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite P205D-S8804 CD Drive Replacement: 5 단계, 이미지 2/2
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 CD Drive Replacement: 6 단계, 이미지 1/1
    • Once the ribbon is released the keyboard can be removed .
  7. Toshiba Satellite P205D-S8804 CD Drive Replacement, CD Drive: 7 단계, 이미지 1/1
    • Flip the computer over with the hinge facing you.
    • Remove one screw that is located in the Toshiba lable on the bottom of the computer.
  8. Toshiba Satellite P205D-S8804 CD Drive Replacement: 8 단계, 이미지 1/1
    • Flip the computer back over and push the metal tab to the right to release the CD drive from its docking port.
  9. Toshiba Satellite P205D-S8804 CD Drive Replacement: 9 단계, 이미지 1/1
    • Remove the CD Drive.
결론
Caroline Camp
회원 가입일: 01/30/17
1 평판
안내서 3개 작성하였습니다
Baylor, Team 3-2, Whitney Spring 2017 Baylor, Team 3-2, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 137
