주요 콘텐츠로 건너뛰기
Toshiba Satellite P205D-S8804 Screen Replacement
필요한 것
  1. Toshiba Satellite P205D-S8804 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • With the screen on a flat surface, remove the screws in each corner of the screen. There will be 4 in total.
    • Note: The screws for the screen may be hidden under rubber pad at the top of the screen so they will have to be removed.
  2. Toshiba Satellite P205D-S8804 Screen Replacement: 2 단계, 이미지 1/1
    • Using a metal spudger wedge open the front and back cover of the screen.
    • Take care to not damage the camera in the process.
  3. Toshiba Satellite P205D-S8804 Screen Replacement: 3 단계, 이미지 1/2 Toshiba Satellite P205D-S8804 Screen Replacement: 3 단계, 이미지 2/2
    • After the front cover is removed remove the two screws at the very bottom of the screen.
    • This will give you access to the screws running along the side of the screen.
  4. Toshiba Satellite P205D-S8804 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the four screws on the each side of the screen. There will be eight in total.
    • We recommend starting from the bottom and working upward.
  5. Toshiba Satellite P205D-S8804 Screen Replacement: 5 단계, 이미지 1/1
    • Lay the screen flat on the keyboard so they the back panel can be accessed.
    • Remove all the tape on the video cable that connects the screen to the computer.
  6. Toshiba Satellite P205D-S8804 Screen Replacement: 6 단계, 이미지 1/1
    • Remove the video cable from the screen.
    • After the video cable is removed the screen is free and can be removed from the computer.
결론
Caroline Camp
회원 가입일: 01/30/17
1 평판
안내서 3개 작성하였습니다
Baylor, Team 3-2, Whitney Spring 2017 Baylor, Team 3-2, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 83
