주요 콘텐츠로 건너뛰기
Toshiba Satellite P50W-C Battery Replacement
필요한 것
  1. Toshiba Satellite P50W-C Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Battery Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Battery Replacement: 3 단계, 이미지 1/2 Toshiba Satellite P50W-C Battery Replacement: 3 단계, 이미지 2/2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Unscrew the four 5 mm JIS #1 head screws holding the battery to the device and gently remove the battery.
  5. Toshiba Satellite P50W-C Battery Replacement: 5 단계, 이미지 1/2 Toshiba Satellite P50W-C Battery Replacement: 5 단계, 이미지 2/2
    • Disconnect the battery from the motherboard by gently pulling out the black connector.
결론
Lawrence Lozada
회원 가입일: 09/25/17
246 평판
안내서 2개 작성하였습니다
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 회원
USFT-CANNON-F17S3G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 940
