주요 콘텐츠로 건너뛰기
Toshiba Satellite P50W-C Hard Drive Replacement
필요한 것
  1. Toshiba Satellite P50W-C Hard Drive Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Hard Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite P50W-C Hard Drive Replacement: 3 단계, 이미지 2/2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Remove the back cover of the device.
  5. Toshiba Satellite P50W-C Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove the hard drive from the device by gently pulling on the blue plastic hard drive cover.
  6. Toshiba Satellite P50W-C Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite P50W-C Hard Drive Replacement: 6 단계, 이미지 2/2
    • Disconnect the hard drive from the mother board by gently pulling out the black connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sarah Fordjour
회원 가입일: 09/25/17
450 평판
안내서 4개 작성하였습니다
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 회원
USFT-CANNON-F17S3G2
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Can you change the touch panel of toshibasatelliteP50W-B1038.
rizwana rizi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 10
전체 시간: 645
