주요 콘텐츠로 건너뛰기
Toshiba Satellite P50W-C Mother Board Replacement
필요한 것
  1. Toshiba Satellite P50W-C Mother Board Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Mother Board Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Mother Board Replacement: 3 단계, 이미지 1/2 Toshiba Satellite P50W-C Mother Board Replacement: 3 단계, 이미지 2/2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: 4 단계, 이미지 1/3 Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: 4 단계, 이미지 2/3 Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: 4 단계, 이미지 3/3
    • Remove all power connections to the motherboard. Including the black and white power connections to the wifi module.
  5. Toshiba Satellite P50W-C Mother Board Replacement: 5 단계, 이미지 1/3 Toshiba Satellite P50W-C Mother Board Replacement: 5 단계, 이미지 2/3 Toshiba Satellite P50W-C Mother Board Replacement: 5 단계, 이미지 3/3
    • Unscrew the two 7 mm JIS head screws in the fan .
    • Then unscrew the four 2 mm JIS head screws connecting the heat sink to the mother board.
    • Then take out the heat sink and fan.
  6. Toshiba Satellite P50W-C Mother Board Replacement: 6 단계, 이미지 1/1
    • Remove both 3mm JIS head screws connecting the motherboard to the device.
  7. Toshiba Satellite P50W-C Mother Board Replacement: 7 단계, 이미지 1/1
    • Remove 5mm silver Phillips head screw connecting black cover to the motherboard
  8. Toshiba Satellite P50W-C Mother Board Replacement: 8 단계, 이미지 1/2 Toshiba Satellite P50W-C Mother Board Replacement: 8 단계, 이미지 2/2
    • Remove all three 5 mm silver JIS head screws connecting the silver cover to the motherboard.
  9. Toshiba Satellite P50W-C Mother Board Replacement: 9 단계, 이미지 1/1
    • You can now gently remove the motherboard from the device.
결론
Brittany Edwards
회원 가입일: 09/25/17
104 평판
안내서 1개 작성함
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 회원
USFT-CANNON-F17S3G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 6
전체 시간: 468
