주요 콘텐츠로 건너뛰기
Toshiba Satellite P55W-C5200X Display Replacement
필요한 것
  1. Toshiba Satellite P55W-C5200X Display Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Display Replacement: 2 단계, 이미지 1개 중 1개
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Display Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Display Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Display Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Display Replacement, Display: 6 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement, Display: 6 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement, Display: 6 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the six 5.0 mm screws that are holding the metal brackets on both sides in place.
    • Gently remove both metal brackets.
  7. Toshiba Satellite P55W-C5200X Display Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement: 7 단계, 이미지 3개 중 3개
    • Remove he three wires connected to the motherboard.
  8. Toshiba Satellite P55W-C5200X Display Replacement: 8 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 8 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement: 8 단계, 이미지 3개 중 3개
    • On the other side remove the four remaining wires from their ports.
  9. Toshiba Satellite P55W-C5200X Display Replacement: 9 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 9 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement: 9 단계, 이미지 3개 중 3개
    • Lift two sets of metal brackets up, one in each corner.
    • Depending on the force needed on your specific device, you may need to use the spudger.
  10. Toshiba Satellite P55W-C5200X Display Replacement: 10 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 10 단계, 이미지 2개 중 2개
    • Gently lift the device away from the display assembly.
    • Be aware of the wires attached to the screen so they don't snag on anything.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hadi Termos
회원 가입일: 10/21/19
241 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G2
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 1,070
