주요 콘텐츠로 건너뛰기
Toshiba Satellite P55W-C5200X Fan Replacement
필요한 것
  1. Toshiba Satellite P55W-C5200X Fan Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Fan Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Fan Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Fan Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Fan Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Fan Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Fan Replacement, Fan: 6 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Fan Replacement, Fan: 6 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Fan Replacement, Fan: 6 단계, 이미지 3개 중 3개
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  7. Toshiba Satellite P55W-C5200X Fan Replacement: 7 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  8. Toshiba Satellite P55W-C5200X Fan Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Gently remove the fan from your device.
결론
작성자
3다른 기여자 명과 함께
Marley Pusey
회원 가입일: 03/27/19
147 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G2
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 587
