주요 콘텐츠로 건너뛰기
Toshiba Satellite P55W-C5316 Back Panel Replacement
필요한 것
  1. Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/2 Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: 1 단계, 이미지 2/2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Back Panel Replacement: 2 단계, 이미지 1/3 Toshiba Satellite P55W-C5316 Back Panel Replacement: 2 단계, 이미지 2/3 Toshiba Satellite P55W-C5316 Back Panel Replacement: 2 단계, 이미지 3/3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
결론
Nicholas Caswell
회원 가입일: 10/19/17
117 평판
안내서 1개 작성함
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 UMass Dartmouth, Team S3-G2, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 950
