주요 콘텐츠로 건너뛰기
Toshiba Satellite P55W-C5316 Battery Replacement
필요한 것
  1. Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Battery Replacement: 2 단계, 이미지 1/3 Toshiba Satellite P55W-C5316 Battery Replacement: 2 단계, 이미지 2/3 Toshiba Satellite P55W-C5316 Battery Replacement: 2 단계, 이미지 3/3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: 3 단계, 이미지 1/3 Toshiba Satellite P55W-C5316 Battery Replacement, Battery: 3 단계, 이미지 2/3 Toshiba Satellite P55W-C5316 Battery Replacement, Battery: 3 단계, 이미지 3/3
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 Battery Replacement: 4 단계, 이미지 1/2 Toshiba Satellite P55W-C5316 Battery Replacement: 4 단계, 이미지 2/2
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alec Bonnell
회원 가입일: 10/18/17
497 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 UMass Dartmouth, Team S3-G2, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G2
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Hello, please I've been searching and searching online to get motherboard for Toshiba Satellite P55W-C5316 but i don't seen to find any. Can anyone lead me to get one to buy.
Owusu Bright - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 2,780
