소개
This guide about removing the battery is fairly straightforward. Be careful to not yank on the connector between the battery and the laptop. Also, make sure that the laptop is turned off before attempting this guide.
필요한 것
Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
The battery is located in the bottom right corner of the laptop.
Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hello, please I've been searching and searching online to get motherboard for Toshiba Satellite P55W-C5316 but i don't seen to find any. Can anyone lead me to get one to buy.
