주요 콘텐츠로 건너뛰기
Toshiba Satellite P55t-A5116 Battery Replacement
필요한 것
  1. Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: 1 단계, 이미지 1/2 Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: 1 단계, 이미지 2/2
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P55t-A5116 Battery Replacement: 2 단계, 이미지 2/2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Battery Replacement: 3 단계, 이미지 1/3 Toshiba Satellite P55t-A5116 Battery Replacement: 3 단계, 이미지 2/3 Toshiba Satellite P55t-A5116 Battery Replacement: 3 단계, 이미지 3/3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Battery Replacement, Battery: 4 단계, 이미지 1/2 Toshiba Satellite P55t-A5116 Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Battery Replacement: 5 단계, 이미지 1/1
    • Gently remove battery from the laptop.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Brittany Castillo
회원 가입일: 01/19/17
878 평판
안내서 5개 작성하였습니다
댓글 9개
The screws for the battery are in very tight and I'm having trouble unscrewing them
Brianna Brucale - 답글
I'm having difficulty unplugging the 10 pin connector. Afraid if I pull too hard it will pull the wires out. Any suggestions?
jmomenee - 답글
Just wiggle it back-and-forth a bit and it should come out. I just change my own battery.
Carmen Cuevas -
I did all of that but my laptop didn’t reboot, any suggestions
roberta - 답글
I had no problem installing the new battery, but even after letting it charge over 24 hours. Not able to get it to turn on
roberta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 31
전체 시간: 22,709
