소개
Use this guide to remove the Toshiba Satellite P55t-A5116 Fan CPU cooler.
필요한 것
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using a PH0 screwdriver, remove 2 (5.7mm) screws.
Using a PH0 screwdriver, remove 4 (3.68mm) screws.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
