주요 콘텐츠로 건너뛰기
Toshiba Satellite P55t-A5116 RAM Replacement
필요한 것
  1. Toshiba Satellite P55t-A5116 RAM  Replacement, Back Casing: 1 단계, 이미지 1/2 Toshiba Satellite P55t-A5116 RAM  Replacement, Back Casing: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 RAM  Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P55t-A5116 RAM  Replacement: 2 단계, 이미지 2/2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 RAM  Replacement: 3 단계, 이미지 1/3 Toshiba Satellite P55t-A5116 RAM  Replacement: 3 단계, 이미지 2/3 Toshiba Satellite P55t-A5116 RAM  Replacement: 3 단계, 이미지 3/3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: 4 단계, 이미지 1/3 Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: 4 단계, 이미지 2/3 Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: 4 단계, 이미지 3/3
    • Locate the RAM cover on the back of the Laptop.
    • Using the #PH0 screw head, remove 1 (5.7mm) screw.
    • Use the plastic opening tool to remove the RAM cover.
  5. Toshiba Satellite P55t-A5116 RAM  Replacement: 5 단계, 이미지 1/3 Toshiba Satellite P55t-A5116 RAM  Replacement: 5 단계, 이미지 2/3 Toshiba Satellite P55t-A5116 RAM  Replacement: 5 단계, 이미지 3/3
    • Pull out the latches on either side.
    • The RAM should pop up.
    • Remove the RAM.
    • Repeat for other side.
결론
Brittany Castillo
회원 가입일: 01/19/17
878 평판
안내서 5개 작성하였습니다
댓글 한 개
I’m confused… it only seems like Step 4 and Step 5 are necessary. Does the battery need to be removed before replacing the RAM? If that’s why Steps 1-3 are there, there’s a lot of steps/information missing. It just goes from “take off the bottom case” to “remove the RAM cover of intact laptop”.
Douggy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 569
