주요 콘텐츠로 건너뛰기
Toshiba Satellite P75-A7100 Motherboard Replacement
필요한 것
  1. Toshiba Satellite P75-A7100 Motherboard Replacement, Fan: 1 단계, 이미지 1/2 Toshiba Satellite P75-A7100 Motherboard Replacement, Fan: 1 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
  2. Toshiba Satellite P75-A7100 Motherboard Replacement, Motherboard: 2 단계, 이미지 1/1
    • Take out all remaining screws in the motherboard.
  3. Toshiba Satellite P75-A7100 Motherboard Replacement: 3 단계, 이미지 1/3 Toshiba Satellite P75-A7100 Motherboard Replacement: 3 단계, 이미지 2/3 Toshiba Satellite P75-A7100 Motherboard Replacement: 3 단계, 이미지 3/3
    • Disconnect the purple and orange ZIF connectors from the motherboard.
  4. Toshiba Satellite P75-A7100 Motherboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite P75-A7100 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove cartridges from laptop by lifting them up.
  5. Toshiba Satellite P75-A7100 Motherboard Replacement: 5 단계, 이미지 1/1
    • Disconnect all wires from the motherboard and replace motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mia Manzanares
회원 가입일: 01/17/18
127 평판
안내서 1개 작성함
댓글 2개
Thanks you very much. Have a nice day
janavas10 - 답글
Gracias. Pero no veo que al remover la placa madre pueda acceder a las 2 ranuras de RAM que están justo debajo del teclado o debajo de los buffers de sonido. Entiendo que debo quitar la placa que cubre el teclado que es una pieza.
janavas10 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 22
전체 시간: 3,488
