주요 콘텐츠로 건너뛰기
Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement
필요한 것
  1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 2 단계, 이미지 2/2
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Wi-Fi Adapter: 3 단계, 이미지 1/2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Wi-Fi Adapter: 3 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 4 단계, 이미지 1/3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 4 단계, 이미지 2/3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 4 단계, 이미지 3/3
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 5 단계, 이미지 1/2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 5 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 6 단계, 이미지 1/3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 6 단계, 이미지 2/3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: 6 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
결론
Brandon Cole
회원 가입일: 01/17/18
323 평판
안내서 1개 작성함
댓글 한 개
¿Como reemplazo el cable blanco?, esta cortado.
Henry Rivera - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 1,033
