주요 콘텐츠로 건너뛰기
Toshiba Satellite P755 S5390 Touchpad Repair
필요한 것
  1. Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: 1 단계, 이미지 1/3 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: 1 단계, 이미지 2/3 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: 1 단계, 이미지 3/3
    • Make sure that your laptop is powered off before starting.
    • Close the cover and turn the laptop over so that the spine is facing away from you.
  2. Toshiba Satellite P755 S5390 Touchpad Repair: 2 단계, 이미지 1/2 Toshiba Satellite P755 S5390 Touchpad Repair: 2 단계, 이미지 2/2
    • Slide and hold the locks on both sides of the battery to the unlocked position.
    • Slide and lift the battery out of its compartment.
  3. Toshiba Satellite P755 S5390 Touchpad Repair: 3 단계, 이미지 1/1
    • Use the Philips #1 screwdriver to remove the 15 screws from the base of the laptop.
    • Keep track of these screws, you will need them in reassembly.
  4. Toshiba Satellite P755 S5390 Touchpad Repair: 4 단계, 이미지 1/1
    • Turn the laptop back over.
    • Open the cover.
  5. Toshiba Satellite P755 S5390 Touchpad Repair: 5 단계, 이미지 1/3 Toshiba Satellite P755 S5390 Touchpad Repair: 5 단계, 이미지 2/3 Toshiba Satellite P755 S5390 Touchpad Repair: 5 단계, 이미지 3/3
    • Using either the iFixit opening tool or your hands, gently remove the keyboard from the base panel.
    • Do not touch the motherboard.
  6. Toshiba Satellite P755 S5390 Touchpad Repair: 6 단계, 이미지 1/2 Toshiba Satellite P755 S5390 Touchpad Repair: 6 단계, 이미지 2/2
    • Check if the touch pad cable is plugged into the ZIF connector on the motherboard.
  7. Toshiba Satellite P755 S5390 Touchpad Repair: 7 단계, 이미지 1/3 Toshiba Satellite P755 S5390 Touchpad Repair: 7 단계, 이미지 2/3 Toshiba Satellite P755 S5390 Touchpad Repair: 7 단계, 이미지 3/3
결론
다른 5명이 해당 안내서를 완성하였습니다.
Dominic Oldani
회원 가입일: 03/19/16
237 평판
안내서 1개 작성함
Michigan Tech, Team 1-20, Lauer Spring 2016 Michigan Tech, Team 1-20, Lauer Spring 2016 회원
MTU-LAUER-S16S1G20
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 6,715
