주요 콘텐츠로 건너뛰기
Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement
필요한 것
  1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • First flip the device over so that the back side is facing upwards
  2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 2 단계, 이미지 1/1
    • Push the two sliders toward the edge of the laptop.
    • Remove the battery.
  3. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Display Assembly: 3 단계, 이미지 1/1
    • Open the lid.
  4. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 4 단계, 이미지 1/3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 4 단계, 이미지 2/3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 4 단계, 이미지 3/3
    • Remove the four screw covers in each of the four corners of the screen.
  5. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 5 단계, 이미지 1/3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 5 단계, 이미지 2/3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 5 단계, 이미지 3/3
    • Remove the 4 screws in each of the 4 corners.
  6. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 6 단계, 이미지 1/3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 6 단계, 이미지 2/3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 6 단계, 이미지 3/3
    • Take your prying tool and proceed to pry the screen cover off and set to the side.
  7. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 7 단계, 이미지 1/1
    • Disconnect the wire from the camera and the backside of the display assembly.
  8. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 8 단계, 이미지 1/3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 8 단계, 이미지 2/3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: 8 단계, 이미지 3/3
    • Remove the 6 screws holding the display assembly and holding brackets together.
결론
Jacob Volcke
회원 가입일: 09/22/22
665 평판
안내서 5개 작성하였습니다
University of North Texas, Team 4-2, Saru Jimmy Fall 2022 University of North Texas, Team 4-2, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S4G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 69
