주요 콘텐츠로 건너뛰기
Toshiba Satellite P775-S7320 Screen Replacement
필요한 것
  1. Toshiba Satellite P775-S7320 Screen Replacement, Screen: 1 단계, 이미지 1/2 Toshiba Satellite P775-S7320 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Begin by removing all of the screws around the perimeter of the screen. There are 6 total.
  2. Toshiba Satellite P775-S7320 Screen Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P775-S7320 Screen Replacement: 2 단계, 이미지 2/2
    • Gently remove the plastic lining of the screen. Use a card, guitar pic, or another tool to pry open the lining, but be careful during this process.
  3. Toshiba Satellite P775-S7320 Screen Replacement: 3 단계, 이미지 1/2 Toshiba Satellite P775-S7320 Screen Replacement: 3 단계, 이미지 2/2
    • Once the plastic lining is loose from the device, you can remove the lining. Gently pop the lining of the screen off of the hinges of the computer.
  4. Toshiba Satellite P775-S7320 Screen Replacement: 4 단계, 이미지 1/2 Toshiba Satellite P775-S7320 Screen Replacement: 4 단계, 이미지 2/2
    • Unscrew the screws located on the sides of the silver part of the screen. Some of the screws are smaller than others, so be sure to get all of them. The screen cannot come off if the screws are not all out.
  5. Toshiba Satellite P775-S7320 Screen Replacement: 5 단계, 이미지 1/2 Toshiba Satellite P775-S7320 Screen Replacement: 5 단계, 이미지 2/2
    • At this point, your screen is almost disconnected. Be sure to support the screen because there is nothing holding it up.
  6. Toshiba Satellite P775-S7320 Screen Replacement: 6 단계, 이미지 1/2 Toshiba Satellite P775-S7320 Screen Replacement: 6 단계, 이미지 2/2
    • Gently remove the tape from the screen. After you have done so, your screen is ready to be replaced!
결론
Addie Reames
회원 가입일: 10/10/16
219 평판
안내서 2개 작성하였습니다
Texas Tech, Team 6-5, Bennett Fall 2016 Texas Tech, Team 6-5, Bennett Fall 2016 회원
TTU-BENNETT-F16S6G5
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 16
전체 시간: 858
