주요 콘텐츠로 건너뛰기
Toshiba Satellite P855-S5102 Optical Disk Drive Replacement
필요한 것
  1. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Push the locking tabs away from each other.
  2. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 2 단계, 이미지 2/2
    • Pull up on the battery to remove.
  3. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, RAM: 3 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, RAM: 3 단계, 이미지 2/2
    • Remove the 3mm Phillips #0 screw from the cover.
  4. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 4 단계, 이미지 1/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 4 단계, 이미지 2/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool to lift up the cover and remove by hand.
  5. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 5 단계, 이미지 1/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 5 단계, 이미지 2/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 5 단계, 이미지 3/3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
Lift the RAM module to an angle of about 30 degrees and slide it out.
  6. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, Keyboard: 6 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, Keyboard: 6 단계, 이미지 2/2
    • Use a plastic opening tool to pry up the keyboard cover.
  7. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 7 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to pry up the keyboard.
  8. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 8 단계, 이미지 1/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 8 단계, 이미지 2/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 8 단계, 이미지 3/3
    • Lay the keyboard upright against the screen.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Remove the ribbon cable from the socket.
  9. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, CPU Cooling Fan: 9 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, CPU Cooling Fan: 9 단계, 이미지 2/2
    • Use a set of small tweezers to pull the 10 rubber caps out of the back panel.
    • Each rubber cap will only fit in the holes they came out of so keep track of which caps go where. If you lose track, there are identification letters and numbers on each cap.
  10. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 10 단계, 이미지 1/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 10 단계, 이미지 2/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 10 단계, 이미지 3/3
    • Remove these thirteen Phillips #0 screws from the bottom case:
    • Ten 3mm screws.
    • Three 2mm screws.
  11. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 11 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 11 단계, 이미지 2/2
    • Remove the four 3mm Phillips #0 screws found underneath the keyboard.
  12. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 12 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 12 단계, 이미지 2/2
    • Separate the top and bottom panels from each other.
    • Try starting from the corner.
  13. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 13 단계, 이미지 1/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 13 단계, 이미지 2/3 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 13 단계, 이미지 3/3
    • Remove the three 3mm Phillips #0 screws from the fan.
  14. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement: 14 단계, 이미지 1/1
    • Disconnect the fan's power from the motherboard.
    • Remove the fan from the laptop.
  15. Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, Optical Disk Drive: 15 단계, 이미지 1/2 Toshiba Satellite P855-S5102 Optical Disk Drive Replacement, Optical Disk Drive: 15 단계, 이미지 2/2
    • Remove the 3mm Phillips #0 screw from the back of the optical disk drive.
    • Slide the optical drive out of the side of the laptop and remove.
결론
Brandon McGuffey
회원 가입일: 01/25/18
339 평판
안내서 3개 작성하였습니다
USF Tampa, Team S20-G3, Passmore Spring 2018 USF Tampa, Team S20-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 359
