주요 콘텐츠로 건너뛰기
Toshiba Satellite P855-S5312 Keyboard Replacement
필요한 것
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: 2 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: 2 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: 2 단계, 이미지 3/3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
결론
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
회원 가입일: 10/02/17
215 평판
안내서 2개 작성하였습니다
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 16
전체 시간: 1,209
