주요 콘텐츠로 건너뛰기
Toshiba Satellite P855-S5312 Screen Replacement
필요한 것
  1. Toshiba Satellite P855-S5312 Screen Replacement, Fan: 1 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement, Fan: 1 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement, Fan: 1 단계, 이미지 3/3
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  2. Toshiba Satellite P855-S5312 Screen Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P855-S5312 Screen Replacement: 2 단계, 이미지 2/2
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  3. Toshiba Satellite P855-S5312 Screen Replacement: 3 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement: 3 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement: 3 단계, 이미지 3/3
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  4. Toshiba Satellite P855-S5312 Screen Replacement: 4 단계, 이미지 1/2 Toshiba Satellite P855-S5312 Screen Replacement: 4 단계, 이미지 2/2
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  5. Toshiba Satellite P855-S5312 Screen Replacement: 5 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement: 5 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement: 5 단계, 이미지 3/3
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
  6. Toshiba Satellite P855-S5312 Screen Replacement, Screen: 6 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement, Screen: 6 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement, Screen: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Turn laptop upside down with the spine facing towards you and locate the microchip.
    • Remove the white and black sliding connector wires by prying upward with tweezers gently pulling the black and white wires upwards.
  7. Toshiba Satellite P855-S5312 Screen Replacement: 7 단계, 이미지 1/2 Toshiba Satellite P855-S5312 Screen Replacement: 7 단계, 이미지 2/2
    • Unplug the single ZIF connector ribbon by gently pulling up.
    • Pull the white and black wires through from the underside of device.
  8. Toshiba Satellite P855-S5312 Screen Replacement: 8 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement: 8 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement: 8 단계, 이미지 3/3
    • Unscrew the four hinges mounting the 1.5mm screws on each side from casing using a Philips #0 screwdriver.
    • Remove entire screen assembly from casing.
  9. Toshiba Satellite P855-S5312 Screen Replacement: 9 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement: 9 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement: 9 단계, 이미지 3/3
    • Locate the two black sticker covers on the bottom of both sides of the monitor
    • Using a pair of tweezers, carefully remove black stickers concealing two screws
  10. Toshiba Satellite P855-S5312 Screen Replacement: 10 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement: 10 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement: 10 단계, 이미지 3/3
    • Using a prying tool, carefully pry along the edges of the screen cover
  11. Toshiba Satellite P855-S5312 Screen Replacement: 11 단계, 이미지 1/2 Toshiba Satellite P855-S5312 Screen Replacement: 11 단계, 이미지 2/2
    • Unscrew the two 1.5mm screws at the bottom of monitor using a Philips #0 screwdriver.
  12. Toshiba Satellite P855-S5312 Screen Replacement: 12 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement: 12 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement: 12 단계, 이미지 3/3
    • With all the edges of the screen cover pried up, carefully remove the screen cover.
  13. Toshiba Satellite P855-S5312 Screen Replacement: 13 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement: 13 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement: 13 단계, 이미지 3/3
    • Using the Philips #0 screwdriver, remove the four 1.5mm screws at the corners of the screen.
  14. Toshiba Satellite P855-S5312 Screen Replacement: 14 단계, 이미지 1/3 Toshiba Satellite P855-S5312 Screen Replacement: 14 단계, 이미지 2/3 Toshiba Satellite P855-S5312 Screen Replacement: 14 단계, 이미지 3/3
    • At the top of the screen, using the tweezers, remove the ZIF ribbon connector by gently pushing it up.
  15. Toshiba Satellite P855-S5312 Screen Replacement: 15 단계, 이미지 1/2 Toshiba Satellite P855-S5312 Screen Replacement: 15 단계, 이미지 2/2
    • Remove the screen from the device.
    • Make sure to be carful because the screen is very fragile.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bishop Clark
회원 가입일: 10/02/17
225 평판
안내서 2개 작성하였습니다
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 744
