주요 콘텐츠로 건너뛰기
Toshiba Satellite R15-S829 Disk Drive Replacement
필요한 것
  1. Toshiba Satellite R15-S829 Disk Drive Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Disk Drive Replacement: 2 단계, 이미지 1/3 Toshiba Satellite R15-S829 Disk Drive Replacement: 2 단계, 이미지 2/3 Toshiba Satellite R15-S829 Disk Drive Replacement: 2 단계, 이미지 3/3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Disk Drive Replacement, Disk Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite R15-S829 Disk Drive Replacement, Disk Drive Replacement: 3 단계, 이미지 2/2
    • Locate the disk drive on the side of the laptop.
  4. Toshiba Satellite R15-S829 Disk Drive Replacement: 4 단계, 이미지 1/1
    • Locate the indent on disk drive on the backside of the computer.
  5. Toshiba Satellite R15-S829 Disk Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite R15-S829 Disk Drive Replacement: 5 단계, 이미지 2/2
    • Use your hand to remove the disk drive by pulling outward.
  6. Toshiba Satellite R15-S829 Disk Drive Replacement: 6 단계, 이미지 1/3 Toshiba Satellite R15-S829 Disk Drive Replacement: 6 단계, 이미지 2/3 Toshiba Satellite R15-S829 Disk Drive Replacement: 6 단계, 이미지 3/3
    • Push the end of a paperclip into the small hole on the disk drive to open it if there is a disk that is stuck in the drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Slater
회원 가입일: 10/20/16
128 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-8, Martin Fall 2016 UMass Dartmouth, Team 5-8, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G8
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 130
