주요 콘텐츠로 건너뛰기
Toshiba Satellite R15-S829 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite R15-S829 Hard Drive Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Hard Drive Replacement: 2 단계, 이미지 1/3 Toshiba Satellite R15-S829 Hard Drive Replacement: 2 단계, 이미지 2/3 Toshiba Satellite R15-S829 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Hard Drive Replacement, Hard Drive Replacement: 3 단계, 이미지 1/1
    • First, begin by locating the spot of the cover of the hard drive located on the bottom of the laptop.
  4. Toshiba Satellite R15-S829 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the screw of the cover.
  5. Toshiba Satellite R15-S829 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite R15-S829 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Locate the indent where the hard drive can be removed. Remove the cover.
  6. Toshiba Satellite R15-S829 Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite R15-S829 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the hard drive using your hand.
  7. Toshiba Satellite R15-S829 Hard Drive Replacement: 7 단계, 이미지 1/3 Toshiba Satellite R15-S829 Hard Drive Replacement: 7 단계, 이미지 2/3 Toshiba Satellite R15-S829 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Now remove the power ribbon from the hard drive.
  8. Toshiba Satellite R15-S829 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Locate the screws on each side of the encasing of the hard drive.
  9. Toshiba Satellite R15-S829 Hard Drive Replacement: 9 단계, 이미지 1/2 Toshiba Satellite R15-S829 Hard Drive Replacement: 9 단계, 이미지 2/2
    • Use your Phillips screwdriver to remove the screws and be careful not to lose the screws.
  10. Toshiba Satellite R15-S829 Hard Drive Replacement: 10 단계, 이미지 1/1
    • Remove the encasing from the hard drive.
결론
Mike Strother
회원 가입일: 10/20/16
299 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-8, Martin Fall 2016 UMass Dartmouth, Team 5-8, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G8
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 414
