주요 콘텐츠로 건너뛰기
Toshiba Satellite R15-S829 Keyboard Replacement
필요한 것
  1. Toshiba Satellite R15-S829 Keyboard Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Keyboard Replacement: 2 단계, 이미지 1/3 Toshiba Satellite R15-S829 Keyboard Replacement: 2 단계, 이미지 2/3 Toshiba Satellite R15-S829 Keyboard Replacement: 2 단계, 이미지 3/3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: 3 단계, 이미지 2/2
    • First, begin by removing the plastic cover that is located at the top of the keyboard. This can be pried off or just removed by hand by grabbing the plastic piece by the indent on either side and lifting up.
    • Be careful to avoid breaking the plastic.
  4. Toshiba Satellite R15-S829 Keyboard Replacement: 4 단계, 이미지 1/1
    • Locate the two screws on each side.
  5. Toshiba Satellite R15-S829 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite R15-S829 Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove the two screws with a phillips head screwdriver. Be careful not to lose the screws.
  6. Toshiba Satellite R15-S829 Keyboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite R15-S829 Keyboard Replacement: 6 단계, 이미지 2/2
    • Lift the keyboard up to reveal the power plug.
  7. Toshiba Satellite R15-S829 Keyboard Replacement: 7 단계, 이미지 1/2 Toshiba Satellite R15-S829 Keyboard Replacement: 7 단계, 이미지 2/2
    • Disconnect the keyboard from the laptop by unplugging the power ribbon.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mike Strother
회원 가입일: 10/20/16
299 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-8, Martin Fall 2016 UMass Dartmouth, Team 5-8, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G8
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 182
