소개
If you need to replace your keyboard on your own, here is an easy process on how to complete this task. All you need is a a new keyboard and a Phillips screwdriver. Be careful while replacing so you don't break anything internally. Now you are ready to get started.
필요한 것
First, begin by removing the plastic cover that is located at the top of the keyboard. This can be pried off or just removed by hand by grabbing the plastic piece by the indent on either side and lifting up.
다른 한 분이 해당 안내서를 완성하였습니다.
