주요 콘텐츠로 건너뛰기
Toshiba Satellite R15-S829 RAM Replacement
필요한 것
  1. Toshiba Satellite R15-S829 RAM Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 RAM Replacement: 2 단계, 이미지 1/3 Toshiba Satellite R15-S829 RAM Replacement: 2 단계, 이미지 2/3 Toshiba Satellite R15-S829 RAM Replacement: 2 단계, 이미지 3/3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 RAM Replacement, RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite R15-S829 RAM Replacement, RAM Replacement: 3 단계, 이미지 2/2
    • Locate the cover where the RAM is located.
    • Locate the screw.
  4. Toshiba Satellite R15-S829 RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite R15-S829 RAM Replacement: 4 단계, 이미지 2/2
    • Loosen the screw for the cover. The screw is attached to the cover, so you don't need to worry about losing it.
    • Lift the cover.
  5. Toshiba Satellite R15-S829 RAM Replacement: 5 단계, 이미지 1/3 Toshiba Satellite R15-S829 RAM Replacement: 5 단계, 이미지 2/3 Toshiba Satellite R15-S829 RAM Replacement: 5 단계, 이미지 3/3
    • Push the two silver tabs outward so that the RAM can move upward.
    • Pull the first RAM module out of the socket.
  6. Toshiba Satellite R15-S829 RAM Replacement: 6 단계, 이미지 1/3 Toshiba Satellite R15-S829 RAM Replacement: 6 단계, 이미지 2/3 Toshiba Satellite R15-S829 RAM Replacement: 6 단계, 이미지 3/3
    • The second RAM is removed in the same way as the first.
    • Push the tabs outward and pull out the RAM.
결론
Justin Slater
회원 가입일: 10/20/16
128 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-8, Martin Fall 2016 UMass Dartmouth, Team 5-8, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G8
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 135
