소개
This guide can be used to locate, remove, and replace the hard drive on your Toshiba Satellite Radius P55W-B5112. This guide is very simple, and details one of the most common types of repairs for this type of computer.
필요한 것
Unplug your laptop from any source of power.
Lay your laptop on a soft, clean surface as shown.
Using the metal spudger, remove the two rubber grips on the bottom face of the laptop, located closest to the hinge.
To loosen the back plate, lift it slightly and gently pull it away from the hinge.
Flip the back plate open towards the power button, but be sure to not pull on the ribbon cable that connects the back plate to the motherboard.
Use a plastic opening tool to detach the side of the ribbon cable connected to the computer by prying up gently on the small black lever at the point of attachment.
Use a plastic opening tool to detach the hard drive's ribbon cable from the computer. Gently lift the black lever at cable's point of attachment to the computer to release it.
다른 2명이 해당 안내서를 완성하였습니다.
