소개
This guide will help you replace/upgrade the RAM on your Toshiba Satellite Radius P55W-B5112.
필요한 것
Unplug your laptop from any source of power.
Lay your laptop on a soft, clean surface as shown.
Using the metal spudger, remove the two rubber grips on the bottom face of the laptop, located closest to the hinge.
To loosen the back plate, lift it slightly and gently pull it away from the hinge.
Flip the back plate open towards the power button, but be sure to not pull on the ribbon cable that connects the back plate to the motherboard.
Use a plastic opening tool to detach the side of the ribbon cable connected to the computer by prying up gently on the small black lever at the point of attachment.
Use a spudger to gently pry up the plastic brackets holding on each RAM drive. The long edges of each drive furthest from one another should pop up at an angle.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Hola estimado, quiera saber el código de la pieza conector hdd sata para Toshiba satellite P55W-B5112
Ya done great, bro!!!! Kudos and many thanks!!!
