주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
We will show you how to remove the back cover, so the computer's internal components are visible.
부품
지정된 부품이 없습니다.
  1. Turn off the laptop before starting.
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Remove the twelve M2x4mm PH0 Philips head screws.
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Loosen the back cover with a plastic opening tool.
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Carefully lift open the cover.
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Devin Boski
회원 가입일: 2017년 09월 20일
391 평판
안내서 3개 작성하였습니다
Can you show replace this model display, and please please, give de part number of the screen
Erick Ramon Garibay Valencia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 878
