주요 콘텐츠로 건너뛰기
Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn off the laptop before starting
    • Remove the two rubber feet closest to the hinge with a plastic opening tool
  2. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Loosen the back cover with a opening tool.
    • The least damaging way to pry the cover is to start from corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Gently lift up the hard drive
  6. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Gently lift up the black tab attached to the strip
결론
다른 6명이 해당 안내서를 완성하였습니다.
Ashley Egenti
회원 가입일: 09/20/17
269 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 16
전체 시간: 1,598
