주요 콘텐츠로 건너뛰기
Toshiba Satellite Radius P55W-B5220 Motherboard Replacement
필요한 것
  1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Using the plastic opening tool, remove the two rubber feet closest to the hinge.
  2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the 12 M2x4mm PH0 Philips screws.
  3. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 3 단계, 이미지 1/1
    • Near the hinges, wedge a plastic opening tool under the back panel.
  4. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 4 단계, 이미지 1/1
    • Unlatch the LED indicator from the back panel.
  5. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 5 단계, 이미지 1/1
    • Using a P0 Philips head screwdriver, Remove the four M2x2.5mm P0 Philips screws from the battery.
  6. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 6 단계, 이미지 2/2
    • Lift the battery.
    • Disconnect the battery.
  7. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 7 단계, 이미지 1/3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 7 단계, 이미지 2/3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 7 단계, 이미지 3/3
    • Disconnect the ribbon cable of the touchpad from the motherboard.
  8. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 8 단계, 이미지 1/2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the two M2x2.5mm P0 Philips screws from the fan.
  9. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 9 단계, 이미지 1/3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 9 단계, 이미지 2/3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 9 단계, 이미지 3/3
    • Disconnect the fan cables.
    • Carefully unhook the wires from the base of the fan.
  10. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 10 단계, 이미지 1/1
    • Unscrew the four M2x4mm PH0 Philips screws from the CPU mounts on the motherboard.
  11. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 11 단계, 이미지 1/3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 11 단계, 이미지 2/3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 11 단계, 이미지 3/3
    • Carefully lift the heatsink off the CPU.
    • Avoid bending or kinking the tubing.
    • Delicately lift the fan out with the heatsink.
  12. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove the M2x2.5mm P0 Philips screw from the USB controller.
  13. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 13 단계, 이미지 1/3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 13 단계, 이미지 2/3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 13 단계, 이미지 3/3
    • Lift the USB controller from the motherboard.
    • Detach the USB controller from the motherboard.
  14. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 14 단계, 이미지 1/1
    • Disconnect the left speaker from the motherboard.
  15. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 15 단계, 이미지 1/2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 15 단계, 이미지 2/2
    • Remove the two M2x4mm PH0 Philips screws for the speaker mounts.
  16. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 16 단계, 이미지 1/1
    • Unhook the speaker from under the hinge cable mounts.
  17. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 17 단계, 이미지 1/1
    • Unhook the right speaker cable from the motherboard.
  18. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 18 단계, 이미지 1/1
    • Remove the copper tape from the speaker cord.
  19. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 19 단계, 이미지 1/2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 19 단계, 이미지 2/2
    • Unhook the speaker cables from under the catch under the hinge.
  20. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 20 단계, 이미지 1/1
    • Remove the eight M2x2.5mm P0 Philips screws from the motherboard.
  21. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: 21 단계, 이미지 1/1
    • Remove the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nicole Kohm
회원 가입일: 09/20/17
131 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 1,648
