소개
The motherboard of your device acts as a meeting point for crucial components, such as the CPU and input and output devices. To replace a damaged or defective motherboard, you will remove all connected peripherals, replace the motherboard, and reconnect all peripherals.
필요한 것
Using the plastic opening tool, remove the two rubber feet closest to the hinge.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
