주요 콘텐츠로 건너뛰기
Toshiba Satellite Radius P55W-B5220 RAM Replacement
필요한 것
  1. Toshiba Satellite Radius P55W-B5220 RAM Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 RAM Replacement: 2 단계, 이미지 1/1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 RAM Replacement: 3 단계, 이미지 1/1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 RAM Replacement: 4 단계, 이미지 1/1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: 5 단계, 이미지 1/2 Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: 5 단계, 이미지 2/2
    • Push outward on the clamps holding the RAM in place.
  6. Toshiba Satellite Radius P55W-B5220 RAM Replacement: 6 단계, 이미지 1/1
    • Remove the RAM chips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Devin Boski
회원 가입일: 09/20/17
478 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 626
