주요 콘텐츠로 건너뛰기
Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement
필요한 것
  1. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: 2 단계, 이미지 1/1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: 3 단계, 이미지 1/1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: 4 단계, 이미지 1/1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement, USB/SD/headphone jack: 5 단계, 이미지 1/1
    • Unscrew the two screws holding the panel of the UBS/SD card/headphone jack
  6. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: 6 단계, 이미지 1/1
    • disconnect the cable shown from the motherboard
  7. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: 7 단계, 이미지 1/1
    • disconnect the cable attached to the top of the USB/SD card/headphone jack interface
  8. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: 8 단계, 이미지 1/1
    • remove the interface
결론
Garrett barta
회원 가입일: 09/20/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 380
