주요 콘텐츠로 건너뛰기
Toshiba Satellite S50-B Cooling Fan Replacement
필요한 것
  1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite S50-B Cooling Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Cooling Fan Replacement: 2 단계, 이미지 1/2 Toshiba Satellite S50-B Cooling Fan Replacement: 2 단계, 이미지 2/2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 1/3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 2/3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 3/3
    • Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
    • Use a plastic opening tool to remove the bottom panel.
  4. Toshiba Satellite S50-B Cooling Fan Replacement: 4 단계, 이미지 1/3 Toshiba Satellite S50-B Cooling Fan Replacement: 4 단계, 이미지 2/3 Toshiba Satellite S50-B Cooling Fan Replacement: 4 단계, 이미지 3/3
    • Locate the 2 screws on each fan. Unscrew them.
    • Disconnect the fan by applying gentle pressure to the circled connection with your finger and pulling.
    • Remove the fans. Be sure to keep track of the right and left fans, marked R and L.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
diana calvo
회원 가입일: 10/17/17
144 평판
안내서 1개 작성함
UC Santa Barbara, Team S1-G4, Weedon Fall 2017 UC Santa Barbara, Team S1-G4, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G4
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 1,457
