소개
The guide demonstrates how to replace a cooling fan for the Toshiba Satellite S50-B. You will need the Phillips #0 screwdriver and the plastic opening tool.
필요한 것
Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
Use a plastic opening tool to remove the bottom panel.
다른 한 분이 해당 안내서를 완성하였습니다.
