주요 콘텐츠로 건너뛰기
Toshiba Satellite S50-B Hard Drive Replacement
필요한 것
  1. Toshiba Satellite S50-B Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite S50-B Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite S50-B Hard Drive Replacement: 2 단계, 이미지 2/2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
    • Use a plastic opening tool to remove bottom casing.
  4. Toshiba Satellite S50-B Hard Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite S50-B Hard Drive Replacement: 4 단계, 이미지 2/2
    • Use the plastic casing over the hard drive to lift the hard drive up.
    • Once hard drive is slightly lifted up, make sure the laptop is in correct orientation with the battery away from you, and pull the hard drive towards right.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Victoria Murillo
회원 가입일: 10/17/17
143 평판
안내서 1개 작성함
UC Santa Barbara, Team S1-G4, Weedon Fall 2017 UC Santa Barbara, Team S1-G4, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G4
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 6,004
